cleaning a plate and frame heat exchanger
zepfan
Member Posts: 397
does anyone know the best mild detergent to use when scrubbing down the plates of plate and frame heat exchanger? the manufacture recommends using nitric acid, and water. I do not want to use any acids if necessary, because we would be scrubbing them down on the roof of the building (rubber roof) thanks to all
What's on the plates?
Nitric acid and mild detergent have somewhat different properties. What is the residue you are trying to remove?0 -
just dirt
Mostly dirt and other stuff found in an open cooling tower system0 -
Try it
can't hurt to try a couple of plates and see how they fare. Sounds like you don't have very hard water there (or have been treating your water diligently.) If you do have lime stains, a lower pH will help -- though Sulfamic, citric, and acetic acids are more commonly used. Nu-Calgon has been recommended here a few times, though I have no personal experience with it.0 -
Acid Free, All-in-One Descaler
Since your heat exchanger made of multi material, in order to not hurt your equipment, I would recommend you to use 1st TECH Biodegradable Descaler. It is acid free descaler, and works for cleaning the rubber material parts.There was an error rendering this rich post.
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
