Is there a truly graphical heat-loss program?
Bob Vennerbeck
Member Posts: 105
I don't do a lot of heat-loss calculations, but those I do, I want to do well, and I want to be able to explain them to 'civilians'.
For the first point, whenever I enter data into HVAC-Calc, or Hydronics Design Studio, I fear (often correctly) that I've mis-measured a wall or window, or forgotten some element entirely. A simple triple check calms that fear, but makes me wish the applications could show a 3-D view of the building, with color-scaled elements to show where the heat-loss is greatest. Not only would it help the designer/data-entry-drone, but it could be used to show the homeowner where the best opportunities for envelope improvement were.
Anyone seen anything like this? Or have the chops to write it? [I sure don't....]
Stay warm!
Vbob
Stay warm!
Vbob
I believe
Wrightsoft uses a graphical model, at least in their mobile app http://www.wrightsoft.com/products/right-j_mobile.aspx
Caveat: I have not tried it yet.0 -
Heat Loss
Wrightsoft! You draw the blueprints and change your parameters. Easy, peasy, lemon squeezy.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
