National Art Radiators
R2.0
Member Posts: 99
I am doing an oil-to-gas conversion of a 1944 brick Cape Cod and I am surveying the existing system. It has a hot water boiler and most of the radiators are labelled "National Art Radiator." They are small tube type radiators, section width 1 3/4", various sizes (most of them pretty large). I am finding VERY little in the way of resources for these. A search on here turned up a statement to the effect that they had standardized by that time and all companies small tube radiators would pretty much have the same radiation figures, but the link to those figures is gone. Any help?
Radiation Tables
Here's a link to Dunkirk's radiation tables. Multiply the square footage x 150 to get the btu output:
http://www.ecrinternational.com/secure/upload/document/414.pdfBob Boan
Radiator btu output
Hey Ice, isn't it a factor of 185 btu/ft?
Are you still down in Florida servicing all their steam boilers?--NBC0 -
Thanks!
I had seen that worksheet before but was unsure of how valid it was.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
