Thermostat
Andrew boiler
Member Posts: 44
Hi I keep my thermistor at 68 and feels like more 65 I have my own zone for my master bedroom.
Any idea what I should set it to
If chilly, set a higher temperature
Have you got an accurate digital thermometer to show the exact temperature?
Until you get one, then raise the setting by 1 degree each time until you are comfortable.
Check any windows in the room for leakage, so there are no drafts of cold air coming into the room.
Get a nice Duvet from Iceland mills to keep you warm until you find the right temperature.--NBC0 -
Turn it up!!!
It is obvious from your frequent posts on this issue the you prefer to have the house warm. I think that rather than saying "it feels like 65", you should simply raise the thermostat until you are comfortable. Problem solved! Who cares what the t-stat says?
Albert Einstein0 -
What
They said.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
