Got a slight problem
Dave0176
Member Posts: 1,177
All might remember the nice install I did on my helpers boiler. Heres the problem when I sized the house up I came up with 243 EDR so I speced a WM EG35 100,000 BTU. The problem was his father and brother were insisting on the EG45 which I told them was waaaay over size, they were going off the old boiler and didn't trust my findings. So he asked for the EG40, I tried to convince him not to do it, and I figured after some installs with me he would listen but he didn't. Mean while he had 4 radiators disconnected but told me to account for them. So now the boiler is installed and he got some issues, he says most don't heat at all, so I went today and replaced half vents and that took care of most the problem. The biggest problem was trying to convince his wife the 4 rads that needed to go back in, well she won, and now he has a waaay oversized boiler. the basement is roasting hot which heats the first floor basically by itself. He gave me that look and said your right I cant complain I picked it. I said your stuck with it now. He could've gotten away with the EG30..........
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Steam
I wouldn't consider that to be WAY oversized. We've seen a lot worse. Any pictures of the boiler?0 -
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Steam
Now I remember. Sounds like you need to do some skimming. That near boiler piping will smooth out any oversizing.0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
