Fresh Air
charliechicago
Member Posts: 130
I am installing a 45,000 BTU %80 furnace in a small mechanical room in a finished attic and would like to bring in fresh air for combustion. Is there a calculation to find out what size pipe I need? Thanks, Mike
Do you have a copy
of NFPA 54 National Fuel Gas Code? If so look in the "Air for Combustion" section. There should also be something in the I & O manual for the furnace.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
