nest thermostat
Andrew boiler
Member Posts: 44
is the Nest thermostat will work with just one zone?
Switch
Yes , the nest will work with a single zone system.
Most thermostats are simple switches. When the temp gets to the set temp they close the circuit. The nest is supposed to track your habits and adjust automatically. It is still just closing a circuit nothing else.
Carol Fey has some great books on controls in the Heating Help Store.
Albert Einstein0 -
Nest
It's not always compatible. Will not just hook to a Triangle. Had to install a relay and transformer to get constant voltage.Just a guy running some pipes.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
