ballvalves
GTD
Member Posts: 31
Where do you get 1/4 ballvalves for the bottom of the sight glass to drain the glass?Thanks tom
valve
look up petcock drain valve onlineRJ0 -
1/4" valve
Personally I used a 1/4" MIP MIP valve along with some fittings from I think Lowes. I did however, swap the valve out for one from pexsupply.com as they have much better valves. I also have a 1/4" plug in the end just in case someone bumps the valve.
https://lh4.googleusercontent.com/-aDgQDYIWlFo/UVtBgYap0CI/AAAAAAAABPc/3ZSQ934NWow/w991-h743-no/DSC04076B.jpgSingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Sight Glass Ball Valve
Hi- this is the best setup I've seen
- Rod
http://www.heatinghelp.com/forum-thread/147223/How-to-detect-dry-or-wet-steam#p13078660 -
Found this valve on Amazon
Very similar to Steamhead's setup.
I have this one installed on my Megasteam 396
http://www.amazon.com/gp/product/B008V64OGG/ref=oh_details_o05_s00_i00?ie=UTF8&psc=10 -
Careful!
That Harbor Freight valve can handle the pressure, but is rated for air line duty. It probably doesn't have a temperature rating and the bottom sight glass drain will be exposed to water from 212 deg. to as hot as 250 deg. at 15 PSI. Give me the valve rated for WOG and at least 250 deg. on the seals!
VABearVABear0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
