Quietest Boiler ?
Andy_27
Member Posts: 17
Hi All,
I recently lost my home to the fires here in Colo. My house had a four zone hotwater system that I loved and maintained. Since I will be rebuilding I would like your opinions on which of the current model boilers are the quietest. The boiler will be on the same level as my home theater system so I want to keep the noise level as low as possible.
I wish there was a way to test drive boilers like cars :)
Thanks
Andy
Thanks
Andy
Gas,oil?
Any gas mod/con is almost silent. With oil,System 2000 is quietest chimney vented. Firebird is quietest direct ventTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Boilers
You should be giving mod/cons a serious look.
Triangle Tube, Lochinvar, and Viessmann are excellent boiler and are well supported in CO. Triangle Tube has training facility in Denver with operating boilers. You may be able to see one run there. You could also have your contractor show you a previous installation.
Albert Einstein0 -
Quiet
I did a home last year that has a vito 100 next to theater room.No sound problems.
Good LuckIf you don't have time to do it right, what makes you think you have time to do it over?0 -
pump
i think pump noise will be bigger issue than mod con boiler noise.Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
installation matters also
Have the installer mount the piping and pumps on flexible attachments.
They have special metal tracks to fasten sheetrock to eliminate noise transmission, consider that for the mechanical room wall.
I installed Lochinvar Cadet in my home recently. It has a thick foam insulation jacket around it for heat loss and noise reduction. Most of the new ECM circs are super quiet.
Have them install a top quality air separator to eliminate any noise from the hydronic piping.Bob "hot rod" Rohr
Living the hydronic dream0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
