This is to good not to share!!
Harvey Ramer
Member Posts: 2,239
I ran across this attemp at stopping a leak on an 410A AC system that I got called out to repair. As Dan would say, this is evidence that a knucklehead was here.
SWEET
Git er done . LMAOYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Duct tape
Probably comes in copper color now!0 -
Leak
Maybe it was better that the person DIDN'T use a torch.0 -
You mean
That didn't work?0 -
Where's
the WD 40 can?0 -
Oh it gets better!
There was no leak at the duct tape location. I found a leak in the Schrader core valves. Whether it made it through the brass service valve caps, i'm not sure.
When I arrived at the site, the unit was going off on high head. Apparently it was cycling like this "on and off every few seconds" for at least a day or two. I pulled probably a pint of dye out of the system. There were noncondensables in the system and 2 lbs. excess refrigerant. Apparently this knucklehead was determined to find a leak. He cut a slit in the armoflex a ways down the lineset and poured dye in there. The dye was then dripping off the pipe right at the coil connection and he told the home owner; look, it's leaking right there, you are lucky you didn't loose it all. His prognosis was that she needs to have the coil replaced.
This guy is either dumber than a box of rocks or a knucklehead or both at the same time with a little bit of "you know what" mixed in. The home owner is a sweet elderly lady who just loves everyone and believes anything she is told. I have not seen anything like this before and while I'm giving the benefit of doubt and trying to find logic in what I see, there is none here.
Scary huh! They are out there.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
