Direct venting steam boiler?
DaveinNJ
Member Posts: 3
We have bought a house with steam heat and a chimney in need of repair. Is there such a thing as a steam boiler that can be vented through the wall and save us the cost of repairing the chimney?
burnham mpo?
I know Burnham carry a power vented steam boiler, IN PV model.its on their website0 -
Power Vent
You can also set up a separate power venter made by Tjerlund or Field Controls. It can be used on any boiler.0 -
Great info guys, thanks!
If either route works out I will save $6000 in chimney repair, which I'd much rather put into new equipment. Thank you!0 -
Cost
The cost comparison will not be very fair until you know what size boiler you need, and what boilers are able to be power vented. You might find that the chimney rebuild is not so crazy of an option.
What repairs need to be done?0 -
So true, Joe
...which is why I said "if"! But I'll give it a shot.0 -
direct vent
I have used Tjerlund in the past, they make a great product with excellent factory supportThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
