Is a Chimney Liner necessary with a Gas Power Burner?
Rod
Hi- Is a chimney liner required when you install a wet based boiler (or convert one from oil) with a gas power burner?
Thanks!
- Rod
Thanks!
- Rod
I believe
I believe so. It certainly is in Nassau County, NY. The flue gas temperature is still reduced as it would be from a conventional oil to gas conversion, causing condensation in the chimney. Without a SS liner, the chimney could deteriorate. The only exemption I've used before is if the chimney runs through the interior of the house only.0 -
It depends
Mass code says it is not required unless conditions warrant it. I recommend doing it as a general thing due to the lower flue temps Like Danny mentioned.Cost is what you spend , value is what you get.
cell # 413-841-6726
Chimney Liner with Gas Forced Draft
Thanks guys for your responses. It would seem to me that most of the applicable codes are written with an atmospheric system in mind and I was just wondering whether having a forced draft made a difference.
- Rod0 -
Stainless steel versus aluminum
Will an aluminum liner suffice OR is stainless steel the only way to go?0 -
Aluminum Chimney Liners.
Hi- I would definitely go with stainless steel. I'm not sure why they even have aluminum liners as aluminum corrodes almost if you look at it wrong. There are also different qualities of stainless steel used for liners. In stainless steel liners, I'm not sure how much actual benefit one would get using a more premium quality over regular 304.
- Rod0 -
Yes it is different with forced draft
If you look at the charts for chimney size it is smaller for forced draft for the same given btu rating of boiler.Cost is what you spend , value is what you get.
cell # 413-841-6726
LINER
MAKE SURE YOU DON'T GET ROBBED. LOTS OF UNSCRUPULOUS CHIMNEY GUYS AROUND. GET A FEW QUOTES. bob nyc lic. plbr0 -
Tile liner?
On our system, the original 1909 chimney is located on the interior of the house and does build up a little heat. The chimney is lined with tile. The boiler(s) have been fired on natural gas since 1954 and there does not appear to be any detioration. I have to note though, that the old Pennco really kept the chimney hot, and the surrounding walls stayed quite noticeably warm. The new WM-680 with Riello burner, running on low fire does not make the chimney hot. There is a little noticeable warmth, but not much.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Running on low fire does not make the chimney hot
Might be interesting to know the flue temp in the top third or so of the chimney.0 -
3rd floor
The highest point I can touch the chimney is at the 3rd floor level. The finished all at that point is plaster directly on the chimney. Warmth can still be detected but not near as much as with the old boiler. The lower temperatures seem to consistent no matter where you are checking.
Of course, the old boiler was an atmospheric with no flue damper. When it was running it had pretty high flue temps and when it was not, there was still a huge draft throught the boiler and up the chimney. The new boiler runs with lower flue temperatures and the new power burner has a little inlet damper that completely closes when the burner shuts down. So, the off time flow of heat up the chimney is reduced to near zero.Dave in Quad Cities, America
ANSI 21.8 Installation of Domestic Gas Burners since
2002 requires the chimney to be lined.0 -
TIM rules
the man has spoken. listen to him. i for one ALWAYS do !! bob nyc lic. plbr0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
