Ferrous nipple used after a backflow preventer
Ron Jr._3
Member Posts: 603
Was wondering if it's code that the piping used between the backflow preventer and a pressure reducer has to be non ferrous ? Considering the prv we use is ferrous , I'm not so sure ......... Backflow is always upstream of the prv . Thanks in advance .
Backflow terminations:
It has always been my understanding as a Massachusetts Licensed Master Plumber that the Plumbing Code ends at the required correctly installed backflow device.
There is a place on a Massachusetts Uniform Plumbing Permit for a Backflow Protection device but NOT for a Pressure relief Valve.
Many of us install a ball valve after the PRV so you can service the assembly and use a brass nipple. Some with less concern of corrosion and obstruction use a steel nipple. I personally do not. For whatever that might be worth.0 -
We use brass
both for the nipple and the PRV. Why ask for rust?All Steamed Up, Inc.
Consulting0 -
Quality Installers:
Quality installers use brass as far as necessary. And it comes apart easier.0 -
I use
brass between them , or copper .
Was just wondering if it's specifically stated in any code to do so .0 -
Ferrous PRV's
,,,"and a pressure reducer has to be non ferrous ? Considering the prv we use is ferrous , I'm not so sure ......... Backflow is always upstream of the prv . Thanks in advance . ",,,
Where are you getting Ferrous PRV's?
I haven't seen any Watts ones that are new for quite a few years. I surmise that there was a problem with Ferrous PRV's were clogging internal screens and lunching boilers when they wouldn't pass water. When I see a bronze colored ferrous PRV's, they usually won't pass water or they won't stop and the only replacements I can buy are all brass. non-ferrous ones.0 -
PRV
I use brass also, but I must say that it is more of a quality issue with valves nowadays. I still have cast B&G's, and Thrush out there that still perform better than the 1156's that are replaced yearly for many reasons.0 -
Iron body PRVs
We use the Taco brand exclusively . And yes Bill , we see 60 year old B+G dual units quite often in Levitt homes . Still working as good as new ! No fast fill , but you can't have everything !0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
