fan coil units
keith_27
Member Posts: 64
How would i figure btu or edr of fan coil units on a steamsystem. There are six coils with fans on one zone of this system. The other zone is 2" baseboard elements. This boiler is about 27 years old and has a small leak at a push joint when it first starts up in the am. It will have to be replaced in the spring.
Click on
Conversion Factors at the top of the page.Retired and loving it.0 -
fan coil units
Thanks dan What forula should be used ???? The coils are all assorted sizes ??0 -
It's
Steam Fan Coil Loads (in pounds per hour) = CFM X Delta-T of air (in degrees F), divided by 800Retired and loving it.0 -
fan coil units
thank you dan0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
