banging n water spitting
wobbie
Member Posts: 1
i have a burnham oil fired burner thats working excellent but i have a banging problem and water coming out of the valves of two radiators. i closed off the radiator in the living room and the banging stopped but i still have water coming up to the radiator in my bed room on the second floor. Do i have a clog or can it be the positioning of my pipes .
PICS?
got some0 -
Could be several things
plugged return line, boiler over-filled, wet steam from dirty water or bad near-boiler piping........
Where are you located?All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
