Sun porch in winter
nelson3694
Member Posts: 1
I'm looking for some creative ideas on converting 24' X 36' sun porch on a 200 yr-old mansion to year-round use. Replacing screens with triple-hung windows is a starting point, but with radiant heat as a goal, what alternatives would you suggest to the 5/4" decking that's there now?
Does a radiant ceiling make sense? It's covered with bead-board right now, so I suppose a thin beaded plywood could be used to lessen the thermal resistance...
Please help stretch my imagination!
start w/
the envelope. Get as much insulation in a possible.Spray foam ? What is underneath? That may be a real challenge. Which way does it face? Some big radiators are prob your best best Radiant floor may be a trick to heat the area all by itself if you have 3 cold walls, lots of windows and a semi exposed floor.0 -
Consider
also what you have done to the adjacent space in the summer.0 -
Radiant may not be your best option
Simplest effective solution imho is a Rinnai ES 38. www.rinnai.us Check it out. Do try to tighten the envelope0 -
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
