Zone Valves
Jimbo_5
Member Posts: 218
Doing new boiler system, hot water fin tube, with 2 zones valves. installing the zone valves on the supply manifold, do I need check valves between the manifold and the zone valves?
Nope
You should not need check valves. Not flow can occur with the valves closed."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
