Removing dip tube in Richardson el
Fizz
Fizz Member Posts: 547
Anyone know how to remove Richardson system dip tube from return of radiator?
  • gerry gill
    gerry gill Member Posts: 3,078
    it should
    be threaded and screw out of the radiator stub...why would you want to though?
    gwgillplumbingandheating.com
  • Fizz
    Removing dip
    Radiator doesn't heat, steam gets to valve, and occasionally will heat top of 1st section.  Have had valve replaced with Mepco orificing.   Radiator is on 2nd floor run off riser, only one heated off it.  System is running on 2-3 oz of pressure with vaporstat, but even when I had pressuretrol, still didn't heat.  converted from oil to gas, and rad has always been under performer.
    Steamhead Member Posts: 16,835
    Try
    cleaning the little hole in the tube that acts as the air vent.
    Consulting
  • Fizz
    That was
    my play, just concerned about running into any problems with removal of tube.
  • Fizz
    Listened to return
    pipe opposite supply riser using stethascope, sounds like faraway toilet or gravel sand with occasional thump or sound like muffled thud, not metalic.  Haven't removed tube yet, will do tomorrow, but had to get feedback on sounds in return.
  • Fizz
    Removed dip still no heat
    Removed dip, air hole clear, didn't remove ball check from elbow,but rotated and cleaned with cloth, no residue on cloth.  Still no heat in radiator.
  • Fizz
