Steam vent ???
Michaelynn
Member Posts: 13
Could you help us ID this old item or might have a PDF to describe it operation. It’s from an old vapor steam system. It has a ¾” NPT connection x 5-3/4” H & is inscribed with #5 Thermodisk, I-39, Jas. P. Marsh & Co.-Chicago. Not certain if it functioned solely as a vacuum breaker and/or an air vent. This was located in the boiler room atop the dry return before piping dropped into a boiler return trap arrangement.
PS CANNOT copy photo of device at this time. Uncertain how to attach file.
Thank you, Mike
Thank you, Mike
Retired and loving it.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
