Circulator size needed
spacoli
Member Posts: 61
Hi to all. I have a room with around 10,000 btu heat loss with two equal loops (235 feet) of 1/2 inch pex radiant floor in concrete.
I need a circulator size with a typical supply and return type manifold (home made tees),required ball valves and mixing valve. Any info, thought or opinions appreciated. Thanks
I would say Grundfos 15-58
Ideally you will push about 2 gpm at a delta t of 10. The nice thing with the 15-58 is you can dial in the speed to get your delta t correct.
Albert Einstein0 -
Thanks
Carl, Thank you for your reply. I will give it a try.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
