Please critique system
stev0
Member Posts: 11
Hi all,
Piping Buderus gas cast iron boiler in primary/secondary. The manual gives no piping diagrams like on many other boilers. How's this look? Thanks for any feedback.
Steve
Steve
Why primary secondary?
Why not just supply and return?0 -
r
gonna add one more zone on manifold for total of 3 and stub seprate short loop for future indirect. zones are small and just wanted to be on safe side0 -
Buderus is fine with
lower return water temps so primary secondary is not used. The design of the return port makes primary secondary piping redundant. Save the price of the pump for the third zone and just pipe it feed and return, unless you have some really cold return temps.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
