pres
Mancave
Member Posts: 5
Any Pros or Cons about Pouring a thin slab over an existing slab for in floor radiant heat? And any input about fastening pex to concrete! Could use some HELP on this one my friends.tkx Mancave...
Insulation?
Is the existing slab insulated?There was an error rendering this rich post.
Anchoring pex to floor
On a remodel we drilled anchors into old floor and set anchors use single hole galvanized clamps every couple of feet. I don't remember how thick the finish slab was but not much more 2 inches. No problems with floor.There was an error rendering this rich post.
If you are going to go to that kind of trouble....
Maybe you should consider using WarmBoard R panel. It was designed with retrofit in mind, and will give a small thermal break between the existing slab and the new heat emitting panel.
It will also perform well with much lower water temperatures than will gypcrete or concrete.
Getting some kind of thermal break between the old slab and the new emitter is critical to overall efficiency, especially if the existing slab is without insulation.
Alternately, consider radiant ceilings using the same R panel. When it is on, the floor is NOT cold.
METhere was an error rendering this rich post.
Radiant in concrete
Yes it is!0 -
Radiant in concrete
Yes it is!0 -
Radiant in concrete
Tkx i will pass that on !0 -
Why not use WWM
If you are going to pour over the existing, why now lay down some welded wire mesh (preferably the mats, not the rolled stuff) to use as a grid for fastening the pex.
I'm not sure what steel mats are costing these days, so it may not be feasible.
Otherwise I would be thinking about something using a powder actuated fastener. Or maybe Viega snap panels.. or warmboard as mentioned earlier.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
