intertherm furnace
karbear64
Member Posts: 1
in Gas Heating
I have an mobile home...the furnace is an intertherm model # mimb070abw.....the red led light is flashing twice.....it says on the furnace that the "pressure switch is open" was wondering what that meant and also what is a pressure switch??? ( I use LP gas)
Thank you......
Thank you......
When the furnace comes on
from all call for heat from the thermostat a blower is energized which brings air to mix with the gas for burning. However before the gas valve can be energized to open and allow gas to flow the "pressure switch" must switch over to power the gas valve. If the pressure switch will not prove the system will not operate.
There could be a blockage or a plugged condensate line, call a professional to come and diagnose and repair your problem.0 -
Call Professional
In addition to Tims comment, please do not try to fix it yourself. This is potentially a deadly problem that needs to be identified. Do not jump out any safety switches even for temporary heat!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
