swing joint
STEAM DOCTOR
Member Posts: 1,973
good evening. what exactly is a swing joint. thanks
swing joint
here is a small one on my boiler reservoir tank. the benefit is that the joint can absorb any expansion, and contraction forces, by allowing a twist at the joint.--nbc0 -
Swing Joints in the Exit Risers
A swing joint is a series of elbows and pipe nipples that allow movement between parts. It's like a universal joint on a car's drive shaft. With steam you probably ran across the term with regard to header piping. Residential boilers are made up of sections which are bolted together (they look like slices of bread bolted together) The end sections have the steam risers attached to them. If the header that joins these end sections is rigid, when it expands, it puts undesirable pressure on sections and the joints between the sections. Adding elbows (swing joints ) to the risers allows for movement and therefore is less likely to cause damage to the boiler. (See attached drawing)
- Rod0 -
thanks
found great article on this topic by Noel Murdoch. steamheating.googlepages.com/headerpiping0 -
Great Link!
Just want to say thanks for sucha great link to the article by Noel Murdoch. It really helped clarify a few things for me. In fact, the entire site is a gold mine of info.Two-pipe Trane vaporvacuum system; 1466 edr
Noel
is one of the best.All Steamed Up, Inc.
Consulting0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
