Erie Boiler Boss
Member Posts: 7,834
Does the Erie boiler boss 4 zone circ control have Normal open and normel closed contacts for each zone?
(Taco and argo only have normal open contacts to operate circulator)
I want to operate steam zone valves that need power to open and power to close
Edward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics
Look at pages 47, and 48 of the Taco zone control wiring guide. We show valves that need 24 volts to open/close so we take a lead off the right hand t terminal at the top of the board where the thermostat is wired too. For your convenience I attached a copy of the Taco zone control wiring guide. Hopefully this helps youJoe Mattiello
Taco Comfort Solutions0 -
Thanks .... but valve motor is 110VEdward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics0 -
What about using a 120v general purpose relay?0 -
I can do that for each zone with no problem... I think that is the way i will end up! I was hopeing for the nice compact look of the multi zone panel like Argo, Taco and the like. I have not used Erie Boiler Boss and I can't find the schematic on their website to see if the 4 zone circ relay has SPST or SPDT (with NO and NC terminals) as the single zone relays haveEdward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
