Source for Anode Rod for Aero Hot Water Storage Tank
HydroAirJoe
Member Posts: 27
My 6 year old home was built with a WMC Boiler and a Aero hot water storage tank (fed by the DHW coil in the boiler). I believe this system is refered to as a Aqua Booster system.
So I happen to read the maintainence label on the Aero and it said the Anod road should of been replaced by now. My question:
Aero was purchased by www.bradfordwhite.com/ so with that said, is there a source (online) where I can purchase an anode rod for this tank? Also I need to add, this tank is in a 4 foot high crawl, so I'll need an articulating rod to avoid cutting plumbing connections to install the replacement rod.
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
