Source for washers?
Ken Johnson
Member Posts: 27
I have been unable to find a local source for replacement washers for steam radiator shut-off valves. 1.25" O.D., 5/16" thick and larger. Anyone know of a mail-order or online source? Thanks.
Made my own
Bought a washer cutter on Ebay; got material from McMaster Carr. Did all of the old shutoff valves.0 -
Sexauer
is a specialty house for repair parts; plumbing and heating. If you can't find a direct replacement in their catalog, do like Ken says and make your own. Sexauer has sheet packing available; catalog #066829 for 1/8" thickness.
Sexauer (800)431-1872
Crest/Good is another source for quality repair parts - (800)862-7378
The people that answer the phones at the above phone numbers presume that you know the catalog numbers of what you want; they get real testy when you start asking questions. I give out their phone numbers so that you can ask for the contact information of your local rep. who may be more willing to bird dog the part you need.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
