Re-Controlling
Plumdog_2
Member Posts: 873
Have a Two-Stage Primary-Secondary setup with Tekmar 4-way mixer for radiant and several fan-coils and two spa heat exchangers and DHW. The smoke has been let out of the 1999 354 Tekmar mixing control, and the 252 two-stage boiler and DHW control is leaking badly. The original installer didn't quite grasp the wiring aspects and has a wallboard covered with transformers and relays. I would like to skin it back to the pump cicuits and stat wires and put in something modular and clean. The boilers are Burnham cast-iron. What do you guys recommend to integrate this stuff?
How About
How about a Viessmann Dekamatik HK-1 Universal with a Tekmar 2-stage boiler control?
-Andrew0 -
I'd like to re-do the whole boiler room if I could; It's not that old really, but definitely "yestertech". This home is 12,000 square feet; foreclosure property. Asset management company wants it saleable, without investing more cash. It begs to be re-done with mod-con.0 -
wiring
The old control strategy seems sound. I would replicate it, only with a bit more finesse than it sounds like the installing tech used. Most cost effectively, a 362 and a 262 would probably fit the bill. It would amount to replacing the original controls with the newer digital display counterparts. There was nothing different about what the original controls did, but your expertise will make all the difference. There is nothing worse than opening an electrical box to find a pile of wires and cube relays.
-Andrew0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
