tubing
Ted_9
Member Posts: 1,718
The info you seek is called a radiant design with a heatloss.
If you've never done radiant heat I highly recommend some training.
Where do you live, we can help you find it.
You can also try this site.
http://www.rpakey.com/
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
radiant tubing
where can i get some info on spacing for infloor heat.
I need to figure out how to best space the tubing for a job
the building is 50 by 50 with only two zones. one is 14 by 50 the other is 36 by 50.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
