Propress Fitting Question
Cliff Brady
Member Posts: 149
Can the FTG end of a propress fitting like a FTG X C have a propress fitting pressed on it?
The Q & A below at Rigid afirms that you can solder a FTG end to a copper fitting, but does not state whether a FTG end can have a propress fitting pressed on it.
Q - Are there ProPress fittings that can be crimped on one side and soldered on the other?
A - Yes. For example, a user can solder the FTG end of a 90° FTG x C elbow and crimp the other end. When doing so, a user must first remove the EPDM seal, solder the other end and replace the seal once the fitting has cooled.
WHY ?? Why would you want to do this ??
yes
you can press the fittings onto a pro-press street ell or ftg x c adapter0 -
Same reason
I would use them for the same reason as using any street fitting as well as the ability to work a greater variety of adaptors into a tee for example.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
