Ultra Fin labor?
JimmyJam
Member Posts: 78
Does anyone have a labor estimate calculation for Ultra Fin tubing and plate installation?
We have never installed Ultra Fin before and need to determine how long it will take to drill all holes (through TJI), pull 1 loop of 1/2" pex and install 113 pairs of plates?
Any ideas?
Thanks!
71Gibby
Any ideas?
Thanks!
71Gibby
hole drilling speed and labor
is what you need to determine. I actually found it easier to run with the joists nand use those pigtail brackets they sell to suspend the tube. Lot less drilling and less kink potential, especially if you use PAP which I highly reccomend :)It does take more tube, however.
If you decide to drill every TGI ever 2 foot or so invest in one of those Lennox single carbide tooth bits. Those suckers carve a hole in seconds. Although not the cleanest cut you will ever see! More of a rip and tear cut, but fast on plywood or wafer board products like I joists.
hot rod
lennox or milwaukee
self-feed 1 3/4 bit when sharp will drill TJI's like BUTTA. Then you can cut armaflex into 1 1/2 inch long sections and stuff it in each hole around the tubing to provide sound deadening. An air powered rivet gun will save bundle of time and severe arthritis from riveting. I would allow myself about 16 hours to do what you describe (by myself, and I'm slow).0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
