Black iron monoflow tees
Robert O'Connor_12
Member Posts: 728
Here's one. This cast iron mono-flo tee I'm guessing was installed in the mid-fifties to "try" and heat a cold porch. As I was evaluating the system for a boiler replacement I noticed them. I said to the HO " I guess this room stays pretty cold eh?" and he replied "yeh, how'd ya know that?". This was on an original open gravity system that someone recently introduced a pump to but couldn't get the house above 50.
Robert O'Connor/NJ
Robert O'Connor/NJ
Do black iron monoflow tees exist? Looked at a job with several large modines all branched off a common supply loop and dumped into a comon return. The only way this could work would be w/ monflow tees in the 2" iron piping. Anyone seen these before?0 -
Yes they do.
monpo-flow
b. & g. makes them and taco used to make a venturi scoop tee. kinda looks like a funnel w/ two ends. still got some laying around the shop from maybe 1970. all 1 1/4 "x 3/4 "0 -
If they all go from supply piping to return piping,
then they shouldn't need monoflow tees. Monoflow tees are used to create a pressure difference between two tees in the same loop. If the piping and circulator are sized properly, then there should be a pressure difference between the supply and return piping, causing flow through all of the Modines. Hope this helps.
Tom M.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
