Old Trick
bob_50
Member Posts: 306
copper isn't made anymore except on special order from the mill in large quantities $$$. What I have done when I needed some 1/4"OD BT to remodel some pneumatic controls and I didn't want to use plastic. Take a roll of 1/4"OD soft, roll it out and fasten one end to a post. Connect the other end to a come-a-long and stretch it until it's strait Then shake it a bit while it's under tension, that work hardens it. Cut it to length and make your bends. Did you ever notice what happens to a roll of soft copper that rattles around in the back of your truck for a while, it gets hard. bob
stretch
Bob, I had a friend who did a lot of control work in a processing plant. He said they stretched the copper a certain number of feet per roll. I forget what he told me but I was surprised they had to stretch it that much
air circulation
if you plugged both ends it may stay soft. the coil of copper that is.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
