Expansion Tank question
eric_2
Member Posts: 148
Thanks Jim, pretty much what I thought. Just wanted a little confirmation.
Expansion tanks
Is there any reason that you can not use more than one expansion tank on a hydronic system? Customer asked me and I just don't know the answer. I can't think of a good reason why not. As always, thanks in advance.0 -
Eric
You can Install as many X-Tanks as you like. They just have to be installed at the same place in the boiler piping system. It is what we call the point of no pressure change. So one big tank or two smaller ones manifolded together the choice is yours. Best Wishes J.Lockard0 -
Be sure to check the precharge (nm)
you can make a header when doing so.....
bracket them all to the wall ,valve them off, with a boiler drain off the end of the header. i know it sounds like a cheap way to do things ...0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
