Radiant: Has anyone tried this
Ted_9
Member Posts: 1,718
Light weight concrete, 5/16 tubing(Viega pex) stapled down to the sub floor with a 1/2 inch pour on the sub floor. Also will be using sleepers for the finish cork flooring. 6" maybe 5" on center tubing spacing.
PATRIOT HEATING & COOLING, INC.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=343&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
By lightweight
do you mean a gyp type product? Check with the manufactures, but I think they want at least a 1" pour over the top of the tube?
Maybe the newer high psi versions gyps could pour that thin?
I have done regular pea gravel redi mix as thin as 1-1/2 inch, but it does crack a lot.
Dan Peel, may he rest in piece, would use a thin, dry pack tile setting mixture as thin as 1".
The key to any thin pour is a very stable subfloor and joist system, to prevent flexing of the floor assembly and potential crack and shifting of the "poured" material.
hot rod
Thanks Hot rod. My hope is that the customer will spend a few and go with the climate Panels.
The cork
I have been around is generally in a tile type product. So check into this first. If it is a cork tile you will need an underlayment plywood or something.
hot rod
done it and used 5/8th \" pour....
however it is heavily doseaged with acrylic and it is in bedrooms that have very little pointed weight type furniture within the room...so far so good.:)it isnt like recommended procedure. however, it works fine...0 -
Have done many bathrooms with 3/8ths Wirsbo Pex on top of tar papered/ wire meshed subfloor covered with highly acrylic'ed concrete base 3/4" to 1" thick.
Haven't had a crack yet. Been doing it for years. Tested it out on my Mom's house years ago and never had so much as a tile bonding issue. I do go thicker with kitchen floors.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
