temperature wont go above 64 with digital thermastat
bill rumsey
Member Posts: 1
the heater wont kick on if I set the temperature on the thermastat above 64.it is a digital thermastat.can you help?
t-stat
Do you have a heat/cool stat? If so, the cooling temp may be set too low and you can't get them closer that 2 degrees apart. check the cooling setting and raise it up then jack up the heat side.
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
