Cast radiator steam valve hole stripped
John Shea
Member Posts: 247
you'll probably want to drill and tap for 1/4" NPT. Then use a 1/4" to 1/8" bushing.
Cast Iron Steam Radiator Valve Hole Stripped
What is the most simple way to re-thread the hole into which the radiator steam valve screws on a cast Iron radiator? I believe the hole opening is 1/8" in diameter.0 -
1/8\" Pipe tap
You need a 1/8" pipe tap. Turn in the tap1/4 turn clock wise in , then 1/8 turn counter clock out...Continue until threads are redone. This action will prevent the tap from binding ,thus breaking which would suck.....0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
