Wall Mount Boiler from NY Thermal? any good
Mark_34
Member Posts: 3
I put a post up last week about looking for a new boiler to replace my 40 yr. system. I had some questions about the WM Ultra cast Aluminum heat exchanger and the problem with the Viessmann vitodens Max water temp of 167 deg F. I came across a wall mounted boiler called the Trinity from NY Thermal. It has a stainless steel condenser and a maximum supply water temp of 200 deg F and 92% AFUE. I talked to one of there sales people and he said they copied a lot of the design of the Munchkin but changed a few of the small problems that the Munchkin had. It cost about $2000 and it will do DHW with an add-on kit. The only problem is I have never heard of them. Does anyone know anything them?
there www page is www.nythermal.com.
Mark
Mark
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
