Mixing w/ reset
kevin coppinger_3
Member Posts: 13
on a boiler that is using outdoor reset will there be problems w/ overshooting? I have heard that you should not mix the two because the 3 way will not "understand" the reduced water temp therefore give too high a water supply to the panel/slab that you are trying to mix down...kpc
Style
Your results will depend on the type of 3 way you are using. A three way thermostatic will try to maintain it's preset outlet temperature regardless of input water temperature. A proportional three way valve is flow based and can follow a source reset. Enjoy....Dan
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Keep in mind
with a 3 way thermostatic you will nee about 20 degree warmer water in the primary, or boiler loop to make them operate, and mix properly. Still my choice.
An non motorized manual 3 way ( dumb valve will not respond properly to changing loads. It mixes on flow only. So if it is connected to a radiant manifold with numerous telestat operators, for example, as more zones open the mixed temperature changes. A semi proportional reset, so to speak!
Just depends on your application how tightly you want to keep that temperature, and amount of control you need.
hot rod
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
