Does this make sense?
Bud_14
Member Posts: 200
When you say "scorched" what temerature are you referring to, because the temperatures are not hot at all on the newer furnaces...say about back 15 years and how fast id the moving air your referring to, cause' most the time you can't feel the air move...not usually. :) Just courious :)
..how hot are those steam pipes..everyone i gave the oooaahah test was "Scorching hot".
Bud
www.Thesheetmetalshop.com
Bud
Wind Chill
I just found this chart on an educational web site.
The chart claims that if it is somewhat warm outside, a wind chill makes it even feel warmer. Does that make sense?
Unfortunately, the chart is in °C and km/h, but the result would be the same.
Mike0 -
When I think about it.
Yes it does. Anything over normal skin temp (85*F or 30*C) would feel warmer if driven by a breeze or wind. I would compare it to a regular oven vs. convection. Don't forget that 40*C is around 104*F if my math is right.0 -
Fair enough...
...your math is bang on. It just surprised me, but your explanation makes sense.
Every day we learn something new. Its beautiful.
Thanks.
Mike0 -
They call it
a heat index around here. Kinda the opposite of a wind chill factor
Inside a building it's often called a draft. The "cold 70" snafu.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Getting latent
There are points above 85° F that perspiration evaporation still takes heat away from the body and cools it, I wonder how high, and how much Relative humidity changes that point up and down. Faster, hot air provides faster evaporation.
Comfort is a tough thing to describe, with numbers. I try to grasp it.
Noel0 -
ever sit in a sauna
and blow on your skin? Same effect.0 -
The same principle
explains one reason why scorched-air or heat-pump systems produce lousy heating. That moving air makes you feel cold!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
