vitoden question
marc
Member Posts: 203
the 2 smaller 24/32 have a internal pressure switch, the larger 44/60 have pressure switch and also flow switch. my question is: in washington state you have two options, lwco, or flowswitch. lwco --- med.-heavy mass (cast) or flowswitch -- copper fin boilers , where does the vitoden fit in . i think it is a fin tube boiler. so flow switch is acceptable. but what do you do on smaller 24/32.
In Michigan
You can use either a flow switch or an LWCO. The module that comes with the Vito has a place to wire either one in directly. Which one you use is personal preference.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
