50a55-112
alex123456
Member Posts: 1
Heater stoped working called tech they came out and he said it was the transformer he also put a bridge with a 5 amp fuse to the transformer.1 hour later the fuse was blown.
They sent anouther tech he said it was the module model # 50a55-112 .The new module is a 50a55-843 this module has a 3 amp protection fuse .After installation it tripped the fuse.any ideas
Something's drawing too much current? The techs they sent out are ...less than competent?
How old is the unit? What, precisely, is happening when the fuse blows? Does the current slowly climb until the fuse lets go, or does it hold steady until something happens? Was any work performed recently? New thermostat maybe?
someone needs to babysit the entire process with a multimeter.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
