Steam from the Sun, and a Possible Use for Carbon Monoxide?
Steamhead
Member Posts: 16,844
Consulting
Consulting
1
I doubt we'll be seeing anything like this in our country for at least another 4 years.Steamhead said:
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I didn't even consider that.................nicholas bonham-carter said:Let's hope it is not eight!!!--NBC
Ugh.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
If they can make the process work, it does suggest another avenue for solar power. Whether or not it would be more cost-effective and energy efficient that using solar generated electricity to perform hydrolysis remains to be seen.
For those with longer memories -- or more reading -- I might venture to point out that coal gas (which had a lot of environmental problems and is, thankfully, long gone!) was a mixture of carbon monoxide and hydrogen produced by heating coal in a reducing atmosphere. The Fischer-Tropsch process can be used to convert that mixture into liquid hydrocarbons, and is currently in commercial use in several countries.
I see that a couple of the comments appear to have political overtones, which is unfortunate. It might be preferable to have the economics and real environmental impacts speak for themselves?Br. Jamie, osb
Sounds more difficult than harvesting algae.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
