Help Rinnai tankless heater RL75 No Ignition
TimR
Member Posts: 2
Hi There, We have a three year old Rinnai RL75 tankless water heater that flows water through it, but will not ingnite. It shows no error codes, the propane tank is 80% full, vent is clear. I have powered it off and on. I also tried entering into Rinnai error code mode, and the unit will just scroll --01--02--03--04--05--06--07--08--09 repeat. I guess that means it is showing no errors? Any ideas would be great.
Thanks!
Thanks!
Thanks for the replys.The water screen I checked and we have good flow. I'll look at the flow switch. Thanks Again!0
I suspect that as noted, the small turbine wheel inside the CW inlet valve is jammed. I think it is easiest to remove the valve. Drop the 4 screws on the bottom of the cold water inlet and disconnect the internal pipes. They are O-ring joints so be careful with the O rings. There is a small snap ring internal that holds the turbine in place. Pull the turbine apart...carefully, and the turbine wheel and shaft will fall out. Wash thoroughly, re-assemble and blow through the turbine. It should spin freely. Reassemble and report back.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
