Boiler Heat and Electric Heat in the same House.
PhilWhite
Member Posts: 2
in Gas Heating
Hi Everyone,
I'm probably the least handy person out there and I cannot seem to find an answer when I google this.
I just bought a house. It's a great little house with a new'ish gas boiler (5-10 years old). There are radiators throughout the main floor that the boiler heats to provide heat to the house. It works great! In fact, I think I am going to like boiler heat much more than forced air.
However, when a previous owner finished the basement and dining room, electric baseboard heat was installed. The kind that has the dial on the wall for the room that the baseboard is in. Throughout the basement and the dining room, there are 4 of these electric baseboards. I know how expensive these can get because this is what I dealt with in college. It's awful.
My question: Is it possible to hook these existing electric baseboards up to my boiler? If so, how? If not, what can I do to eliminate this electric baseboard heat?
No you can not hook the electric base boards up to a hot water boiler system. Water flows through the existing radiators.
However you may be able to buy radiators, and or base boards to tie into the existing system for hot water heat.
That's a start. There is much more to it, and I'm suspicious as to why the electric was installed rather than tieing in to the hot water heat.0 -
You can replace these baseboard electric with hot water baseboard........however some fair amount of expense could be involved.
IIWM, I would go thru a heating season and check the operating costs. Basements are usually not that hard to heat, you may be surprised that you don't see the costs of your previous home.0 -
It's called "cheapness".Gordy said:...... I'm suspicious as to why the electric was installed rather than tieing in to the hot water heat.
Consulting1 -
Well my first thought.....pay over time with electric I guess.
Could have been a DIY basement finishing project. The electric BB htrs would be the cheapest and maybe the whole project was homeowner wiring......sometimes scary.
But it was unfinished and unheated other than pipe losses and most likely not freezing pipes. Could be an easy heat if walls got insulated.0 -
Is the dining room an addition on a slab (no basement underneath)?
If not, the heating circuit can be cut from an adjacent room and redirected to pick up the dining room.
In the basement, if you don't want to add a zone to the boiler, you could look into installing a ductless A/C, heat system.0 -
First thing is first.
I know you are not an avid DIY. But does the areas with electric baseboard appear to not lend itself to running water pipes off the hydronic heating system?
Some pics of the rooms in question. With pics of adjacent rooms with hot water heat, and basement same thing.0 -
Good point!0
All,
Thank you so much for the responses. The kitchen is NOT over the basement. It is on a slab. The boiler is a hot water boiler.
I'll try and get some pictures up tonight.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
