High pressure steamers.
Timco
Member Posts: 3,040
Need to swap this 10hp with 15hp.
Suggestions on brand names?
Fulton or LattnerRJ0
Or Columbia0
Ok. How are you guys moving these out & in???Just a guy running some pipes.0
There usually on a channel iron skid. Pipe rollers would be one way depending on how much room you have to maneuver maybe a pallet jack0
Why are there 3 pressuretrol on that boiler?
Hi-Lo firing?--NBC0 -
cant tell from the picture but that is a Power Flame model J burner. They offer those in fixed fire, lo-high-lo or full modulation. Cant tell from the picture what that one is.
1 pressure control is probably an operating control, the other would be a manual reset safety high limit.
the third could be lo-high-lo or modulating control. If the burner does not have lo-high lo or modulating control the third control could be used for maintain a lower pressure at night or off hours (like a night setback)0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
