adding wall control to control heat and a/c for high rise condo unit with convectors
rosn
Member Posts: 1
We own a one bedroom condo unit on the 39th floor of a high rise. Each unit has convector units that control the heat and air conditioning. If we want to add wall controls to control the heat and a/c, what type of contractor do I contact.? I believe the overall heat and a/c is controlled by a boiler system.
An HVAC/Mechanical contractor that knows commercial controls.Bob Boan
While you are looking for the right contractor, can you tell us about the problems you now have with the system? Are you too hot in winter, or too cold in summer?
I suspect that this is a symptom of a system wide problem, and that all work on the system should be done by the condo regime, as it is a common element, like the roof. If botched work is ever performed on one unit, it can have a negative effect for everyone.--NBC0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
