Floor heating in bedroom?
FSTHD
Member Posts: 1
In typical bedrooms you do not have much exposed floors to enjoy the benefits of radiant floors. Beds, dressers, furniture, and often carpet limit the output of radiant.
Heat flux is the term to describe the amount of room floor space divided by any furnishings that cover the floor surface and eliminate radiant transfer to the space.
Panel radiators are nice as they can easily be zoned and offer fast start up and shut down for using temperature setback options.
Radiant ceilings and walls are other options.Bob "hot rod" Rohr
Living the hydronic dream2 -
No form of heat "holds" dust anywhere. Visible dust particles settle out of the air very quickly after being disturbed by shaking out a blanket, for example. The bedroom has a lot of potential for air quality issues. Carpeting holds dust and if you have a vacuum cleaner that doesn't trap the dust particles well, it just blows them all over the place. Dead skin cells, dust mite debris, pet and human hair all can be part of the mix. Cosmetics like hair spray and face or body powder can also cause an issue. Forced air heat blows the air around thru ductwork. Visible dust particles are too heavy to ever make it to the filter or air cleaner. Smaller particles stay airborne longer and can be minimized by filters or electronic air cleaners. Microscopic dust can be picked up in the air currents that occur around radiators and convectors. Others mentioned that the furniture in a bedroom can reduce the efficiency of radiant floor heat, and that is true.
You can minimize dust by removing carpets or rugs. Hardwood, tile or linoleum don't hold dust like rug fibers do, but can be cold underfoot unless you have in-floor heat. There are individual powered air filtration units that you can put in your bedroom to minimize the dust, but removing the source of the dust is the best way to forestall problems.0 -
My bedroom (house) has radiant floors 10 years now. Very comfortable. Keep my BR at 69°.
As far as dust, there is no dust. I don't start to see dust until AC comes on during the cooling season.steve0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
