Hot water boiler problems
Electricalguy
Member Posts: 1
Well the relief valve was triggered at 30 psi. But here is the rub. The boiler was off. So must be the pressure reducer because city water is 70 psi. Changed out the pressure regulator...Watts 1156F and the pressure relief valve 30 psi. Boiler still hitting the 30 psi and dumps. Remove the expansion tank and install new Extrol SX-30V. Boiler still dumps at 30 psi. Currently boiler is off and temp reads 100 degrees. Pressure is over 30 psi and dumping water....Help
Does the boiler have a domestic hot water coil or an indirect water heater tank?0
coil on the boiler or indirect coil has failed? have you shut off the fill valve to the boiler?0
You guys beat me to the punch.
If an indirect, I'll say it's a Superstor, Weil McLain or Triangle Tube bladder tank. Wagers?0 -
I bet Tankless coil, too.
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
