Looking for Control replacement, Capable Controls?
GW
Member Posts: 4,692
in Gas Heating
Hello, local peerless vendor doesn't have this in stock, anyone know if there's a universal? Tim are you online this morning? Thank you
Sorry it didn't load as an image0
Sam 81 got it right the S8610U will replace this control. Capable is sort of a copy of Honeywell controls along with another company called ICM.0
Thaks! Tim so in general if I see Capable or ICM I'm good with the Universal Honeywell?0
Yes as far as Intermittent pilot and HSI. The S8610U from Honeywell covers Int Pilot the S8910U covers HSI. Capable also has a comparable version to Honeywell DSI which is replaced by the S87 or S89 for Direct Spark Ignition.0
Tim, I'm stick trying to pick away at my notes, so there are no universal S87 or S89? No sense on keeping those on the truck right?0
OK good to know, I don't see these DSI controls much, but good to know. Thanks0
Yes thanks I know about the charts, I hardly ever see DSI though. And the Capable Controls isn't listed on the S8610U sheet.
Are the pages on the web sites able to be loaded into a spreadsheet? Thet would be great to build a library, load into Google drive0 -
Gotcha. I've been seeing more and more of those Capable Controls too. The name itself worries me a little. : )Steve Minnich0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
